ā2009-03-02
07:37 AM
ā2023-05-26
02:42 PM
Rubia Torres
ā2009-03-02 08:16 AM
ajg wrote:The 2D plan visibility issue might be "Floor Plan Cut Plane" related. Try adjusting the settings there; but before doing that, try setting the windows' floor plan display mode to "Symbolic" and see if that changes anything.
They are also not visible in the 2D-plan window.
ā2009-03-02 02:35 PM
ajg wrote:Check your Model View Options (which are saved with the Views), specifically the Options for Construction Elements > Window Options. With what you describe, it looks like this is set to "Hide on Floor Plan" rather than "Show on Plans", which will also "hide" them in the elevations, but not the 3D Window.
I have a strange problem where the windows are evident in 3D, but when I switch to an elevation, they disappear!
ā2009-03-02 11:56 PM
ā2009-03-02 11:57 PM
ā2009-03-03 03:12 PM
