Windows not visible in elevation
Hi all,
I have a strange problem where the windows are evident in 3D, but when I switch to an elevation, they disappear! They are also not visible in the 2D-plan window.
If anyone can help, I'd really appreciate it.
BTW: Using Arch v.12.
Thanks in advance. 🙂
5 Replies 5
The 2D plan visibility issue might be "Floor Plan Cut Plane" related. Try adjusting the settings there; but before doing that, try setting the windows' floor plan display mode to "Symbolic" and see if that changes anything.
And one more thing: I'm guessing that you are using the windows from the AC12 Library. They have been reported here as having bugs, so the advice would be using the AC11 Library until the next update is released.
Adrian Tudoreanu
David Maudlin
Check your Model View Options (which are saved with the Views), specifically the Options for Construction Elements > Window Options. With what you describe, it looks like this is set to "Hide on Floor Plan" rather than "Show on Plans", which will also "hide" them in the elevations, but not the 3D Window.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David, that did it. Thankyou.
adytc - Thanks for the advice, also. Much appreciated.
And thanks for the signature advice. 🙂
David Maudlin
Adam:
I'm glad the solution was so simple, signature looks good
David
