2013-10-28
02:48 PM
2023-05-24
09:08 AM
Rubia Torres
2013-10-28 02:52 PM
2013-10-28 02:53 PM
2013-10-28 02:54 PM
2013-10-28 10:49 PM
2013-10-28 11:33 PM
Miki wrote:Not so unless I've missed something over the years. The window location will be based on the anchor for the window (head or sill) and where it touches the profiled wall... as well as the opening lines set in Profile Manager.
Where is the center of the profile? This dictates the window location.
2013-10-28 11:35 PM
YS1616 wrote:I'm not fully seeing the problem in your screenshots... If your Floor Plan Cutplane is through that upper, unsupported (?) wall segment, then the window should appear inside that wall in plan. The section views suggest that you have the window anchor set to 'sill' and have it above the jog in one view, and slightly below the jog (picking up the outer wall surface) in the other view.
Any reply will be appreciated,
2013-10-29 11:29 AM
Karl wrote:YS1616 wrote:I'm not fully seeing the problem in your screenshots... If your Floor Plan Cutplane is through that upper, unsupported (?) wall segment, then the window should appear inside that wall in plan. The section views suggest that you have the window anchor set to 'sill' and have it above the jog in one view, and slightly below the jog (picking up the outer wall surface) in the other view.
2013-10-29 11:30 AM
2013-10-29 11:31 AM
