archigreen
How can I copy&paste a perspective view map to another file?
How can one copy & paste a perspective from the view map to another sister-file?
I know the perspective settings:
- Camera Z
- Target Z
- Distance
- Azimuth
- View cone
- Roll Angle
- Sun Altitude & Azimuth
What I do not know is the precise location of that view.
Can I convert that view into a camera and copy & paste that camera to the other sister project?
Any thoughts?
ArchiCAD 26
MacOS Monterey
MacBook Pro Apple M1 Max
64 GB
Have you tried to copy/paste a camera? I have not and don't know if you can, but the easiest way to find out is to try it.
If it does not work, copy and paste a column or other easy to find element at your camera location and then use your know values.
Of course You can copy-paste cameras.
The plain old cameras(an paths) are the easiest way to insert a pre-seted sets of views (in therms on settings that would be propagated to the new 3d views not only the points of cameras) in template.
Best Regards,
Piotr
