We value your input!
Wood Floor Help
Hello everyone,
I'm having a doubt on Archicad 15 abou modeling a wood floor. I want to model an interior wood floor but I want to do it so that when I do a section I see the direction of the wood finish correctly according to the section direction. I added a small scheme where I have direction A where I see the top of the wood floor and direction B where I see it's length - and the opposite for the wood "stripes" that support the wood floor. Is there a simple way to do this or I should do it in 2D?
Thanks in advance
Do it in 2D, is easier that way
Use the object "Battens for Roof Tiles 15.gsm" in AC15 Library.
Thanks for the quick answer guys. I will try it with battens first and if I'm not satisfied with the end result I will do it in 2D!
