Working with modules on USB
Hi, I have a problem with modules. I have a library on a USB stick that contains modules. When I clone this USB stick so I can work at home with the same modules, it can't find the modules. I know I could use a BIMserver but somehow I can't seem to access it from my home. I would rather take along my modules on an USB stick and plug it in at home. This would also work if internet fails.
Is there a solution to this?
I hope someone can help.
Thanks!
3 Replies 3
Is the network path for this cloned USB exactly the same as the original?
The path will need to be exactly the same on your work and home machines.
I have also moved this post to the 'Working in Archicad' section of the forum.
Hi Barry, Thanks for the reply. The USB is plugged directly in my mac. I can plug the usb in my home computer and it also works there. I found out that the path in the hotlink manager is /library/... and when I use the other usb (cloned) it showes /volumes/library/... After some searching on the internet it probably has to do with the ID number of the usb sticks. So I'm going to try and change that number somehow... Anyway, I hope that one day we can choose for relative paths!! (a wish that was made almost 9 years ago according to the forum here).
Regards,
