Learn more
Working with morph
I am creating a roof. I find very useful to edit the slope of the roof in the section view, you can move end points of edges and increase the slope or decrease it. I have the following questions.
1 After editing the roof I get some diagonal lines in plan view like if were marking the polygons of the faces. Can I get rid of it?
2 Is It possible to move several points of a morph at a time?
3 When I am splitting a morph that have several boxes or volumes I cut all of them. IS it a way so I can split part of a morph not all the morph through the plane. (In auto cad you can do cut and then separate in parts so you can erase the part you need)
1 Reply 1
Lingwisyer
Guru
Set your edges to Hidden or Soft?
Ling.
