Worksheet Viewports
I want to create Interior Elevations but DO NOT want to use the Interior Elevations feature because it creates separate views for each wall. This is very annoying and not useful.
I like the worksheet feature because it's a linked marker that can be re-built from the 3D-model. I want to use the worksheet feature.
My question, is there any way to have multiple linked viewports in ONE worksheet? In otherwords, I want to create a linked worksheet with viewports from both the plans and sections. With this I can then add 2D information and create Interior Elevations in ONE worksheet.
thanks
mps
This is not possible to do as you described it.
If you want to have the drawing info of each related Interior Elevation and the Floor Plan in one view then you should create these Interior Elevations, then place them plus the floor plan on a Layout, then use that Layout as a Trace Reference in the viewpoint you are working.
This way you will see all those other views.
