Worksheets: Copy to new project
Johann_P
I have 2 projects open simultaneously.
One project has multiple independent worksheets with text that I would like to copy to the second project.
Is there a easy way to copy these worksheets between projects?
ArchiCAD24 - since Nov 2020
Revit - 2005 to 2020
Windows 10 Pro
2 screens: nvidia quadro RTX 4000
Erwin Edel
Add the worksheets to your template, so new projects already have them in place.
You can copy the text itself around easily enough.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Erwin Edel
You can't copy 'independent' worksheets. You will have to create them one by one and copy the contents.
At least, as far as I know.
www.leloup.nl
Johann_P
Perhaps there is then a better way of doing the notations:
The particular worksheets only has text notes: Legends of fire ratings, General Notes, Survey wavers, Abbreviations, etc.
Would there then be a better way of creating these notes to easily copy them from project to project?
Windows 10 Pro
Erwin Edel
www.leloup.nl
