Johann_P
Worksheets: Copy to new project
I have 2 projects open simultaneously.
One project has multiple independent worksheets with text that I would like to copy to the second project.
Is there a easy way to copy these worksheets between projects?
ArchiCAD24 - since Nov 2020
Revit - 2005 to 2020
Windows 10 Pro
2 screens: nvidia quadro RTX 4000
1 Solution
Erwin Edel
Add the worksheets to your template, so new projects already have them in place.
You can copy the text itself around easily enough.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Go to post
3 Replies 3
Erwin Edel
You can't copy 'independent' worksheets. You will have to create them one by one and copy the contents.
At least, as far as I know.
www.leloup.nl
Johann_P
Perhaps there is then a better way of doing the notations:
The particular worksheets only has text notes: Legends of fire ratings, General Notes, Survey wavers, Abbreviations, etc.
Would there then be a better way of creating these notes to easily copy them from project to project?
Windows 10 Pro
Erwin Edel
www.leloup.nl
