‎2008-03-05
06:02 PM
‎2023-05-26
02:50 PM
Rubia Torres
‎2008-03-05 09:58 PM
‎2008-03-05 10:44 PM
Link wrote:Thanks Link to rescue between sleep less nights.....
Can you show a screenshot with a better explanation of what type of trace reference is not in the correct position?
There is a 'Reset to Default Position' command on the Trace & Reference palette.
Link.
‎2008-03-05 10:45 PM
‎2008-03-06 12:27 AM
‎2008-03-06 12:37 AM
Link wrote:Thanks a mil. for info & assuring I not going crazy. yet!
Yes, it's all a bit of a mess isn't it. I don't knowallthe idiosynchrasies, so will leave that open to someone who does.
What I can tell so far about referencing on the floor plan is that a referenced linked detail, will position the reference relative to the detail origin. That's the little cross you see in the middle of the detail bubble. A referenced linked worksheet will position the reference relative to the project origin. A referenced linked section/elevation will also position the reference relative to the porject origin.
For independent viewpoints, layouts and masters, the position of the reference seems rather random, although I am sure it has some logic that the GS programmer in the back of the room probably only understands.
And that's just for referencing in the floor plan! Until this is explained futher and/or fixed, I would suggest just using the 'Drag Reference' command to position your references.
Link.
‎2008-03-06 08:11 AM
‎2008-03-06 06:20 PM
Link wrote:This window only shows up when the elements go beyond the window of plan view, other wise pasts to the Reference Location automatically; no control.
At least they have given us the option to paste relativetothe reference location (when pasting into a reference viewpoint).
Link.
‎2008-03-06 11:53 PM
‎2008-03-07 02:27 AM
