Llian
ZONE CATEGORY COLOR ON PLAN
There is no colour on plan; but when printed on black & white, it is showing a shade. Two questions:
1. How do I get to have different color on the plan?
2. Why there is a shade showing on the black& white print when there is no color showing on plan?
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
2 Replies 2
The zone colour is controlled by the settings for your zone categories.
You can create Graphic Override rules that make zones transparent, or have a solid foreground or background fill, etc.
There should be standard rules already set up, but if not have a look in the standard template and export them so you can import them into your files.
I would be guessing that in plan you are using a GO that is making the zones transparent.
But in the views that you are printing, they are using a different GO where the zone colours are showing.
Llian
Thanks Barry.
I have figured that out…added the zone fills in graphic override.
Learnt something new...
