2013-09-09 10:09 PM
2013-09-10 03:03 PM
2013-09-10 05:27 PM
2013-09-10 05:36 PM
2013-09-10 05:48 PM
2013-09-10 06:07 PM
2013-09-11 02:59 PM
gdford wrote:I think this is very similar to the problem created by the same materials in different files having different index numbers. If you search the forum you will find posts about this issue and a few workarounds. Probably the solution is to move away from index numbers for all attributes, but that cannot be done easily, I don't remember if Graphisoft has addressed this issue in the forum.
Is there any thought around Graphisoft about moving away from indexing attributes by record position and toward using a Unique ID? This would solve issues in coordinating attributes during the merging of models.
