2012-01-12
11:53 PM
2023-05-24
01:00 PM
Rubia Torres
2020-09-17 04:53 PM
2020-09-18 03:45 AM
drexdis wrote:
+3.00 on first story
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
2020-09-18 04:06 AM
2020-09-18 07:51 PM
Lingwisyer wrote:No, the ground floor is from 0.00 to +3.00 and the first story is from +3.00 to +6.00.
Is that higher than the surrounding walls?
2020-09-19 05:37 PM
Barry wrote:Hi Barry, i think the settings of the zone and the walls may be essential in solving this. There are walls separate on each storey, the don't go further than their storey.
If you are placing a zone in the same storey as the wall home storey, then you can set the base height of the zone above the wall height and you can still place it with the automatic placement methods.
However if you are in a storey above your wall's home storey (but you can still see them as they span multiple storeys), then the base of the zone must be below the top of the walls or you must set the 'Home' of the storey to be that same home storey as your walls.
But be aware if you set the zone home storey to be the one below the current storey, it will place the zone but you will not see it on the upper (current) storey, as zones can not display on multiple stories like walls can.
So basically you can place a zone on each storey, but if your walls span multiple storeys, then the base of the zone on each storey must be below the top of the walls.
If you have separate walls on each storey there should be no problem.
2020-09-21 03:28 AM
2020-09-21 03:34 AM
2020-09-21 10:08 AM
drexdis wrote:Hi,
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-09-21 06:08 PM
Lingwisyer wrote:As i mentioned, if i set the base zone to 0.00 it works perfectly (but in reality it is on first storey so it has to be +3.00). The boundary is closed so that is not the problem.
Given your second image, I would suggest cutting up your zone with temporary walls to find out where your closed polygon issue is.
