Zone Stamp text background fill
Hello,
I'm in Archicad 15 using Zone Identifier 2 15. Is there is way to assign a white background fill to the text so it stands out if there is, for example, a floor pattern behind? It seems there was an option for this in 14, but no longer in 15? Manually placing fills is becoming a bit tedious...
David Maudlin
rpinkham:
I do not see that option for the Zone Identifier 2 14. Are you sure that is the Zone Stamp you used? The Zone_Stamp_IFC_01 has that parameter.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
I may be mistaken regarding the AC14 object. I see that the IFC stamp has that parameter, but lacks other options such as the justification of text. Anyone using the Master Script object? Does that have a background fill option?
