Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Zone drawing - What is it?
Hello.
That means this parameter?
Thank.
3 REPLIES 3
I think it means that if this parameter is referred to in a Graphic Template, it will actually display the drawing of the Zone Polygon currently being listed.
Laszlo
Thank you.
May be.
How anybody does it?
May be a Zone Drawing is element of Property Script šŸ˜ž
I think it is mentioned in the GDL Manual. Or check the following link on ArchiGuide:
http://www.graphisoft.com/support/archicad/archiguide/simpleelementsched.html
It talks about Elements, not Zones, but it has an example of how to create a drawing for the element which will be displayed in the list.
Laszlo
