2022-08-23 04:33 PM
All of the labels in projects show these zeros. Thank you for any help!
2022-08-23 06:50 PM
I think that’s a setting in Project Preferences under the File menu. You can set the number of decimals for certain items. You can also set dimension styles that you can save for different views depending on what accuracy of dimensions you require.
2022-08-24 12:28 AM
Is this a legacy project pre AC25? Zones now have independent labels and the previous label data may not be transferring correctly to the new Zone Label.
2022-08-24 03:07 AM
Depending on the type on information being displayed by the label, it could be Project Preferences > Working Units or Calculation Units.
You will need to adjust the decimal precision.
2022-08-26 10:57 PM
Thank you for your replies. I have been trying working units and calculation units under preferences. That isn't it unless I am missing something.
I tried editing the object itself, and I don't know what else to do...thank you for your feedback.
2022-08-26 11:14 PM
I ended up duplicating the object and moving it to the Archicad 26 library. The original stamp object was on an embedded library. It worked. Thank you!
2022-08-27 12:07 AM
Opened another teamwork file on the BIMcloud, and the 0.000 returned...
2022-08-27 12:13 AM
When I open the Zone Stamp properties, I am not allowed to choose a different library object...the object is picking it from is in the embedded library. It's not on the ArhiCAD 26 cloud library
2022-08-27 07:30 AM
The Zone Stamp is controlled within the zone categories in attributes.
