Scott Bulmer
Zone names not listing in schedules
I have placed zones for each room within a building. The zones extend to the reference lines of the exterior walls. Although each zone has the same category, they each have their own unique room name and cover fill colors.
Only one zone name (of approx. 20) appear in any schedule. What would cause this?
Thanks,
Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
12 Replies 12
Aussie John
have you checked something odd in the filtering section of the schedule.
I think you will need to post more information - maybe a sample file
Cheers John
[/size]
Scott Bulmer
Hey John,
Thanks for your response as I'm stumped.
In the attached file, the NCS Door & Frame schedule list most of the zones, but not all. In the NCS Window Schedule or list, only 1 or 2 of the zones are listed. For some of the rooms I moved the zone edge further out to the face of the wall (past the reference line), but that did not seem to have any affect.
I'm certain you're busy and I appreciate this.
Scott
Aussie John
HJi Scott there doesnt seem to be any data in the file except for a section marker
Cheers John
[/size]
Scott Bulmer
Hi John,
For some reason when I create a mod file, it saves with the zoom way out. I downloaded the previous uploaded file, and verified that is the case. At your convenience, could you please look at the file again with zoom to fit in window; it should work?
Thanks again,
Scott
Link
Scott,
The default schedules you refer to don't actually list zones or any part of them AFAICS, so you will probably need to export these schemes settings and upload the zipped XML files too.
Link.
Aussie John
I redownloaded the file and the info was there this time??!?!?
as far as the schedules of the zones only -
I used a basic schedule and all your zones showed.
I also set up an interactive schedule and that worked too.
But if you wish to see the zone when scheduling a door or window the zone edge must touch exactly the face of the wall. The merest offset will not recognise the zone
Cheers John
[/size]
Aussie John
Scott wrote:
The zones extend to the reference lines of the exterior walls.Thanks,
Scott
I just noticed you said this. As I mentioned in earlier post the zone must go to the face of the wall. Best way to achieve this is use the zone update. The zone must be completely enclosed by zone defining elements. Walls or lines or circles.
Walls are set by default but lines/circles must be checked to act as a zone boundary
Cheers John
[/size]
Scott Bulmer
John/Link,
Thanks for your help/time on this as I think I've got it worked out.
Originally I had modified the default schedules to include Zone Names. Also when defining the zones, I had traced the wall reference lines using the Zone Manual Construction Method. I had not used the zone update feature that may have caused some of the problems. One notable repeatable issue came out of this however;
For all exterior doors and windows, the zone had to be placed such that it extended past the exterior wall by a minute fraction, or else the Zone Name would not list in either an interactive door/window schedule or list.
This is a repeatable problem (at least on our workstations) and I believe is likely related to the 10 library doors/windows than zones. Now that we have extended the zones past the face of the exterior walls, all the Zone Names properly list in the Door/Window schedules.
Thanks again,
Scott
I assume that your doors swing out? There should be a hotspot on the doors to switch the zone it reports (from outside = none) without otherwise changing the door. This will also work with interior doors that are reporting the wrong room (zone) number.
