Zone names not listing in schedules
Scott Bulmer
I have placed zones for each room within a building. The zones extend to the reference lines of the exterior walls. Although each zone has the same category, they each have their own unique room name and cover fill colors.
Only one zone name (of approx. 20) appear in any schedule. What would cause this?
Thanks,
Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
12 REPLIES 12
Scott Bulmer
Matthew Lohden wrote:
I assume that your doors swing out? There should be a hotspot on the doors to switch the zone it reports
Yes, the doors swing out! Matthew, I cannot seem to find the hotspot parameter you refer to, the closest being 'Show all Hotspots' under 'Floor Plan Symbol', which doesn't seem to have any affect. At your convenience could you please direct me to the correct setting?
Thanks,
Scott
Did you ever get an answer or figure out how to get the door hotspot to show up? I'm struggling with the same issue and can't see the alleged hotspot for referring to Zones.
Thanks!
I am experiencing the same problem. I cannot find the hotspot either. Any help would be appreciated
