Zones in 3D perspective
I've a question about the zones in 3D. I want to show only de construction elements with the fire compartments for an architectural impression. Only when I've add the zones into the model in 2D, they don't appear in the 3D view.
Which configurations have to be adjust?
It could be that they are turned off in the 3D filter as they are in the attached image.
@ Barry Kelly
Thanks! That was the solution for my problem!
