Zooming to a Mesh
I have worked in both the PC and Mac environment with ArchiCad. Recently I upgraded my G3 Tower to a PB G4 with AC 8.1 and for some reason when I zoom into a selected mech in the 3D window, none of the ridge points are visable in the zoomed view. The mesh is still selected, but I can't see the points. This seems to happen only on my Mac.
Anyone else run into this?
Regards,
Tanny
1 Solution
It sounds like a display driver problem, but I have had no such trouble with my PowerBook 17". I have the GeForce4 MX w/64MB vram. If you have one of the newer machines it is probably the ATI 9600.
You can download the compatibility info at:
http://www.graphisoft.com/support/archicad/archiguide/videocardtest.html
Go to post
