‎2008-06-23
09:22 PM
‎2023-05-26
11:31 AM
Rubia Torres
‎2008-06-23 09:54 PM
‎2008-06-24 01:20 AM
TomWaltz wrote:Definitely correct, but it would be great (essential?) if the casing could be turned off globally in conjunction with 'core only'
Archicad shows the wall with just the core, so the casing floats away from the core.
Technically, it is correct, since the casing still acts as through the finishes are there, just that the finishes are just invisible.
‎2008-06-24 07:10 AM
Chris wrote:Didn't have the chance to open AC12 yet, but I'm sure that you can use this new feature with the "model view options", it's just one setting to ask the hole to stay visible but not the casing.TomWaltz wrote:Definitely correct, but it would be great (essential?) if the casing could be turned off globally in conjunction with 'core only'
With all due credit to the work that goes into each new feature and release, this is where those new features have a tough time making it from good idea to real-world application. So it's great to have the core only feature but floating casing may mean that many won't use the feature. I'll have to see how it looks, but there's no good solution. Even with cadimage doors/windows which allow more control, the trims are either on or off for plan view. It might be possible to use pens, but more experimenting will be needed. With AC doors/windows, you can't adjust casing separately as far as I know.
‎2008-06-24 09:50 AM
‎2008-06-24 11:47 AM
Til wrote:Model view options affect sections and elevations, but not the 3D window, so it depends on which view you want to look at.Chris wrote:Didn't have the chance to open AC12 yet, but I'm sure that you can use this new feature with the "model view options", it's just one setting to ask the hole to stay visible but not the casing.TomWaltz wrote:Definitely correct, but it would be great (essential?) if the casing could be turned off globally in conjunction with 'core only'
Am I wrong ß testers ?
‎2008-06-24 08:50 PM
‎2008-06-26 03:03 PM
zucoc wrote:No changes. One of my major gripes...
Are there any improvements in priorities?
for example slab and wall with different composite structures interact with each other or it's like in ac11?
‎2008-06-26 04:59 PM
‎2008-06-26 07:08 PM
James wrote:I use the cadimage door and window builder a lot and asked them about this - they say it's being incorporated into their v.12 update so I'm hoping for the best. AC shoudl also get this integrated in to their objects
The new global GLOB_STRUCTURE_DISPLAY reflects the partial structure display condition.
So D/W could be scripted to omit casing when finishes are off, e.g.
Not the answer that most people who want the casings handled as finishes but don't want to script D/W want to hear.
