again, on display order in relation to windows
Here's something odd: I have a solid fill rectangle, and two diagonal lines indicating a cut member in plan section: I called them all to the highest level of display order, and yet, in juxtaposition to the window sill, the lines appear above, while the fill-box is below. What is up with that? All new lines I draw and call to the top will course right over the window, but the fills...aren't.
1 REPLY 1
Aussie John
The display order doesnt always work as expected. If you call an element to the top of the stack then try to bring another to thte top it doesnt always supersede the previous elemnts position. In that instance try and send the problem element backwards rather than bring the other element forward.
BTW you cant send a window back and forward - you have to send the whole wall
Cheers John
[/size]
