arc & segment in opening door and windows
how i can use arc roof in below the roof
in another problem
when i use a opening windows or opening about arc
i have a little segment betwen arc and in render
i have a bad render in arc opening windiws
how and where i can change and fix distand betwin segment in arc opening a have a better render in light work render
1 REPLY 1
David Maudlin
Hadi:
I don't know which door you are using, but in the AC 9 Special Edition library, the door D1 Segmented SE9, in the Parameters section, under "3D Representation" there is a parameter "Curve Resolution". Increasing this number makes a smoother arc. If this is not the door you are using, look for a similar parameter.
HTH
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
