archicad 11 + virus !
Today my antivirus (avira antivirus) detected some kind of virus or what. Virus is on original cd and i download archicad directly from GS, both containing this !
What will i do ???
I would suggest to change the antivir software.
Try some web scanners (other vendors) to check if the other solutions detect the same.
Best Regards
Piotr
Suspicious Files and Miscellaneous Uploads
Thank you for your submission. Below you can see the current status of the uploaded files.
A listing of files alongside their results can be found below:
File ID Filename Size (Byte) Result
2231044 InputOutput.dll 512.5 KB FALSE POSITIVE
Please find a detailed report concerning each individual sample below:
Filename Result
InputOutput.dll FALSE POSITIVE
The file 'InputOutput.dll' has been determined to be 'FALSE POSITIVE'. In particular this means that this file is not malicious but a false alarm. Detection will be removed from our virus definition file (VDF) with one of the next updates.
Please note that you will receive an email which will contain the results shown above. In case the final outcome of the analysis is not yet finished for all files the notification will be sent once ready.
