archicad 21 distance please help!!!!1
hello! i am using archicad 21, so when i started project line, wall, ect distance was right but in one day i noticed that line, wall distance is growing every 5cm..but it doing only on this project when i start new project everything is fixed. it is like 1100 -1150 -1200... idk how to fix it please help!!
1 Reply 1
In the Standard Toolbar you can find the "Grid Snap" button.
Under its options you can check if either the "Snap to Snap Grid" or the "Snap to Construction Grid" options are turned on. That can cause this behaviour.
