2018-12-2101:13 PM - last edited on 2023-05-2408:15 AM by Rubia Torres
2018-12-2101:13 PM
hello! i am using archicad 21, so when i started project line, wall, ect distance was right but in one day i noticed that line, wall distance is growing every 5cm..but it doing only on this project when i start new project everything is fixed. it is like 1100 -1150 -1200... idk how to fix it please help!!
In the Standard Toolbar you can find the "Grid Snap" button.
Under its options you can check if either the "Snap to Snap Grid" or the "Snap to Construction Grid" options are turned on. That can cause this behaviour.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac28
