2004-08-19 09:40 PM
2005-01-17 07:48 PM
tprokop wrote:Can you pull the Building Systems objects into ArchiCAD? If so, does it do a decent job? What kind of elements does ArchiCAD use to represent the objects?
We now run Archicad for our architectural department but found it limited for engineering needs so our engineering runs Building Systems...The key to it all is to make sure your set-up and standards work in translation between the formats.
2005-01-18 05:41 AM
2005-01-20 09:59 AM
ricki_faris wrote:IFC is the only viable option, as there is a chance of a snowball in hell of any software company opening up the file format or unifying the file format.
IFC seems to be the platform from which this may be possible. However, the issue is:
Who will DEVELOP these exporters & importers??? I have yet to see this process (even 3D/BIM export from ArchiCAD to external software) - please enlighten me if others have seen...
