Showing results forΒ
Search instead forΒ
Did you mean:Β
Search instead forΒ
Did you mean:Β
archicad stock library parts missing lines
Hey all,
I have just recently started working in 11, and I am having a heck of a time with the library parts. A few of my stock library parts are missing lines. The archicad tub, and the multi-sink. Is there an upgrade somewhere, or is there something I have done wrong in the settings? I know there is no way that graphisoft could have released something pre-maturely, without all the bugs worked out. remember 8? Is 11 the new 8? Suckered again by budapest. Is a subscription really worth it?
3 Replies 3
If I am correct you are looking at these object in a Section View or Interior Elevation View in which you see them from the side.
In that case the curved parts of the outline of the object is not visible. It is like it is not there.
This is actually a shortcoming of GDL and those Library Object have been like this for as long as I know the program.
Usually there are 2D side views of such objects in the Library to be used in such cases.
no actually it is in plan. The multi sink is the one that is really bugging me. Graphisoft is looking at the issue now. We will se what they come up with.
OK, sorry, then this must be a different issue than the one I thought of.
