attaching Autocad dwg's
Hello,
I'm trying to attach Autocad dwg's using the merge command - the drawings are placed at an angle and at a different scale in the Archicad dwg. Any tips. I've checked my ucs in autocad - all is well.
I'm using ArchiCAD 9 - thank you
6 Replies 6
Eduardo Rolon
Check your translator settings for the scale so that the Units settings mathces the one in AutoCAD. AS for the rotation if it is not too inconvenient rotate it in AC...
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Djordje
C:\Program Files\Graphisoft\ArchiCAD 9\Graphisoft Documentation\DXF-DWG Conversion Guide.pdf
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Not in my folders in US?
Any other possible locations?
Thanks,
Joseph
Djordje
It should be in the Documentation folder under your ArchiCAD folder. Might be a different name in the US installation.
Djordje
HP Omen
Erika Epstein
Your installation CD
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Thanks,
Joseph
