auto sizes for 2D?
Can somebody advice pligin or addon for Archicad 8, which put sizes betweeen objects on 2D plans automaticly (huge plan with a lot of furniture, passes e.t.c.)?
5 REPLIES 5
Dwight
Would this be some kind of auto-space? No such function exists - to create a fixed gap between objects.
I suggest that you add outrig hotspots in your object plan symbols to establish offset sizes, but this will interfere with parametric resizing of the element.
Dwight Atkinson
Djordje
You might try to show the usage space; I have to check (not using 8.1 for months now ...) whether the 8.1 objects still have the usage areas defined, but I do remeber that the 6.5 and 7.0 ones did. And, they had the htospots. Very easy to line up furniture with necessary passages with that feature on.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Dwight
learn something new every day. here it is:
Dwight Atkinson
Djordje
Yep, that one.
Djordje
HP Omen
Since years, i never found which use for this parameter.
Thanks for the highlight. Yes, something new every day.
