back to the fray
somehow, for some reason, dark and unknown...I am getting these fat line returns arond the windows. I want the lineweight to be the same as it wraps the wall...must be a radio button somewhere, a slider or dial or toggle or...any hints? thank you!
19 REPLIES 19
Erika Epstein
In the composite settings dialogue box there is a place where you can chose your "skin end lines".
You can pick which pen you want for these ends, or check the 'hide' box..
the skin end applies also to edges cut by doors, windows etc.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
thanks for your response, and I looked into the situation on my composite--I turned off all of the end lines, to no changes. So...another ccause? Here is another -and slightly more disturbing (or illuminating?) image...it appears that this thick line occasionally wraps the window, following the trim. Maybe a window setting, but I can't for the life of me figure it out.
Erika Epstein
It also looks like you have your composite skins set to turn in.
Check "cavity closure" settings in your window dialogue box.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
I'm not sure I looked at the right place...for the "cavity closure" situation...the attached jpeg shows a little box in the lower right, labelled "contours", which I fiddled with. I also messed with about 4 other variables in the window selection settings box...no single variable seemed to change anything, except when I unchecked the "use fills" dialog box in the 2D settings box, that seemed to do it. But oddly enough, other windows, which were not misbehaving, had the "use fills" box checked. The inconsistency of performance is driving me up the wall. It almost seems like a "display order" function, but it is my understanding that the windows and the wall they are embedded in are always represented at the same "level". thank you...!
the image
Erika Epstein
Zobi,
Which window library are you using?
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Its the SE9. Does that change things? Maybe more variables available to me to be disturbed by?
Erika Epstein
Zobi,
It is in the same place in the SE library as the old one.
Look under the Parameters tab.
See attached.
If you set it to 'None' that should take care of it. If you want the closure wrapping then go back to the composite dialogue box and choose a pen with an appropriate lineweight
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
hot dog! that looks worthy of exploration. Funny little hidden boxes...everywhere in this program.
A thousand thanks.
