beam junction problem (forced joint)
Hello, 'I have 2 wood beam intersected, they are forced to joint at sharp shape, but I don't want them to joint, but how?
normally not all element must be forced to jointed once they touched ?
Thanks
1 Solution
Lingwisyer
Guru
Beams will always do that. Move the reference line so that they do not intersect or change the intersection group of one of them. Though, with your current reference lines, it should work if you just shorten them to match your diagram...
Ling.
ps. This thread should probably be under Working in Archicad
Go to post
3 Replies 3
Lingwisyer
Guru
Ling.
Post has been moved - please try to post in an appropriate section of the forum, not just 'Archicad +'.
This is a little frustrating.
For walls, the reference lines have to touch before they will trim together.
With beams they will trim if any part of them overlaps.
The only way I know to avoid this is as Ling suggested, putting each in a different layer with different layer intersection priority numbers (or the same layer with a priority of zero).
Or you could play around with segmented beams and adjust the segment sizes so they only just touch and not overlap.
ok Thanks Barry and Ling
