Gus
can I stop beams and walls from auto connecting?
There have been many times when I wan't to turn off the function where beams automatically lengthen in order to meet up with one another. Can I turn this off somehow? Same thing happens with walls sometimes.
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W [email protected]
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
9 Replies 9
David Maudlin
Gus:
Change the Beam Priority of one of the beams (Beam Settings > Floor Plan and Section > Structure), the Beams' reference lines cannot intersect. For Walls, they need to be placed on layers with different Layer Intersection Group numbers.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Gus
Thanks David. I will give those things a try. I visited your website from the link at the bottom of your post. I like your work. Take care.
Michael
Madison WI
David Maudlin
Thanks for taking the time to look at my work and posting back.
David wrote:
Gus:
Hey David,
Strange as it may sound, but I didn't know this.
I learned something new today about ArchiCAD.
What do you know?!
David Maudlin
Strange as it may sound, but I didn't know this. I learned something new today about ArchiCAD. What do you know?!
Hi Laszlo:
I could have written that quote. This is one reason I like to follow most of the forum threads, I can learn more about the details of ArchiCAD.
laszlonagy wrote:
David wrote:
Gus:
Hey David,
What do you know?!
If I change the beam priority then the reference lines still trim together in plan.
It just affects how the trim each other in 3D - i.e. which one has prioriy over the other.
Or am I just misunderstanding what the original request was?
David Maudlin
Barry wrote:
...Or am I just misunderstanding what the original request was?
Barry:
The Beam Priority can be used to show separated beams when the reference lines are inside the second beam. Depending on the Priority, the results will vary. This is a simpler solution than using different Layer Intersection Group numbers, but that may be required depending on the needed results. The Walls do not work this way. The Beams' intersections in 3D are also affected.
Must be a Mac thing?
It doesn't matter for me if I click on the front edge or inside the beam below or above the reference line - the reference line all trim automatically.
Priority strength maes no difference.
The only time they don't trim is when I click outside below or above the beam.
David Maudlin
Barry:
I doubt it, except for system specific items (like font handling) there hasn't been much difference between the Mac & PC versions. I cannot reproduce your result, don't know which setting is the cause.
