can i find curved sofa in library of archicad or method ?
Hi sometimes i want flexibilty even in furniture so i have curved sofa i want to put it in archicad is it available in archicad library or is there an addon if there is a way let me know and thanks
There are lots of furniture models available. Start with the depository.
If that doesn't have what you need search in the Library parts forum for other links to downloadable parts. There are quite a few.
mm i tried in depositary but did not find i found on archibase with 3ds formula i know there is goodies in graphisoft website converting it from 3ds to gsm but i think almost things did not created inside archicad is even will be distorted in in 2d and sometimes in 3d as well plus it is heavy so i will try to create sofa using complex profile --profile manager save it as object for further using as it is inevitable
