can not see the window through walls in plan !!!
Hello
I work on V.11
I have a simple question...I use dwg reference below
I draw walls for example, and it comes with hatch...when I am about to add the windows ...I can`t see where the windows are !!!
how can I manipulate wall opacity or what is the best method to work?
any help would be appreciated
7 REPLIES 7
Eduardo Rolon
Select the wall and change - Floor Plan Settings - to Cut Only.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
sorry
I am new in Archicad...
how can I change it? do I need to go the menu above? or through the wall settind dialogue ? (cuase there I didn`t see)
thanx
I think I found it...but it doesn`t do anything !!!
can I simply make opacity or something? is that too complicated?
by the way...I am working on 1.storey and the drawing reference is in 0. ground floor (I don`t know how to move the drwa to 0.ground floor)
Document/ model view options/ options for fills and zones/ show cut fills contours only.
also... R.T.M. 😉
Eduardo Rolon
and check your "Floor Plane Cut settings" so that you are cutting the wall at the correct height.
AC29 US/INT -> AC08
another Moderator
One more thing, if still having problems.
Check to see what the height of the story is you are working on.
I have found that a story has sometimes ended up at very short height, (1'-6") for what ever reason, I don't know, but things will look normal in 3d, but not in 2d, even if your: "Floor Plane Cut settings" are correct.
Bier
thanx !
finally I succeeded !!!
