License Delivery maintenance is expected to occur on Saturday, October 19, between 4 and 6 PM CEST. This may cause a short 60-minute outage in which license-related tasks: license key upload, download, update, SSA validation, access to the license pool may not function properly. We apologize for any inconvenience.
2008-01-2408:28 PM - last edited on 2023-05-2506:12 PM by Rubia Torres
2008-01-2408:28 PM
I am opening a project and I am unable to insert windows in the walls. Doors are fine. When I try to insert a window ( any window ) I can select the library part, change the parameters and then select the wall.
When inserting it gives me the eye icon but after that the window just doesn't show up ( when inserting it looks like there is a grey'ed out line )
starting a new file works fine, it is just this one...
What is your cut plane set at? Another thing to check is your Floor Plan Display setting of the window you're inserting. From what you've said it's not that you can't insert it rather you just can't see it once you do insert it.
