‎2008-11-03 02:26 AM
‎2008-11-03 02:31 AM
‎2008-11-04 08:05 AM
‎2008-12-17 02:11 AM
‎2008-12-17 02:22 AM
Dale wrote:To simply invoke the standard AC12 Command Layout Scheme (which has the Trace & Reference palette already in the menu), you'll need to go to Options> Work Environment> Work Environment... then in the left pane click on Command Layout Scheme. And on the right select Standard Commands 12 and hit the Apply Scheme button. Then hit OK.
How do I "invoke an AC12 command layout scheme" and how do I "add the Show/Hide Trace and Reference command" to my existing menu structure?
