centerline symbol (CL)
We have switched fonts from ArchiTEXT to ARCHITXT. Unfortunately, the ARCHITXT does not seem to have a centerline (CL) symbol. Before I reload the old ArchiTEXT font just to get the centerline symbol I thought that I'd ask if there is another way to produce the centerline symbol.
Is there a way to get the centerline symbol without loading the ArchiTEXT font?
Thanks,
John
fhedberg
You could always download the symbol object from the depository....
http://archicad-talk.graphisoft.com/object_depository.php?browse=Depository/01%20General/Graphic%20S...
Hope this helps...
W11 Home | ArchiCAD 27 3001 AUS FULL
Link
As fhedberg said, our good man James has already come to your rescue...
http://archicad-talk.graphisoft.com/viewtopic.php?p=62805&highlight=centerline+symbol#62805
Link.
Ah fhedberg,
Thank you, that works brilliantly.
Aloha,
John
