2012-04-2112:06 AM - last edited on 2023-05-2302:42 PM by Rubia Torres
change edge angle of shell
2012-04-2112:06 AM
Hello everyone. i've just created my first shell, woo hoo! it's a barrel roof, but in changing the shape of the shell using "define shell contour" command, now one edge of my extrusion is plumb, instead of being perpendicular to the shell face. i've played with the tools and tried AC help, but can't find out how to change it. i've attached a pic, i hope this is clear.
wb
The Shell contour is basically a vertical extruded body. The Intersection Solid Element Operation is performed between the Shell body and the defined Shell contour. This gives the shown result.
Try instead to achieve the desired geometry by creating Holes in the Shell. Then you can rotate the Hole body in 3D so that it cuts at the angle you want.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac29
