2012-04-18
05:14 AM
- last edited on
2023-05-26
02:27 PM
by
Rubia Torres
2012-04-18 02:35 PM
SADSNa wrote:You can set the wall to Cut Only, then adjust the Floor Plan Cut Plane for each View so the Cut Plane does or does not cut through the windows. Walls left on Symbolic Cut will not be affected.
I have created a floor plan view setting and reflected ceiling plan view setting. Is it possible to show the clerestory on the reflected ceiling plan view and not have it show on the floor plan and vice versa with the windows at typical head height?
SADSNa wrote:The visibility of Markers can be controlled via the Model View Options (MVO) which are part of each View. The size and marker options depend on the Marker being used.
With window setting in general: Is there way to turn off the windows markers on one plan and not the other and edit the window size note or only have the window marker and not the size?
2012-04-18 07:35 PM
2012-04-19 02:44 PM
2012-04-23 06:37 PM
2012-04-24 02:08 PM
