complex wall caping modelling
I need to model a piece of exterior "standalone" wall with a complex caping profile. I am not highly acquainted with GDL modelling and cannot see how can I model this with "regular" AC objects.
Suggestions on how can I accomplish this are most welcome.
Please see attached DWG for object elevations.
Many thanks in advance and I apologize for posting an Autodesk non-BIM file. 🙂
I am using AC13.
Joaquim
6 REPLIES 6
Use Beam from Complex Profile to cut the top of the Wall.
Hi Andro55
Many thanks for your help. How do I subtract the beam from the wall?
Joaquim
SEO - solid element operations
The wall being the target element and the profile being operator element
It´s not necesary. Read the text on my picture!
A bit more explanation about the SEO method:
http://www.archicadwiki.com/ModifyTheSideContourOfTheWall
Ralph Wessel
Mentor
Take a look at OBJECTiVE. It will make this task very easy. I simply selected the shapes you drew, created an Elevation profile for it with OBJECTiVE > Component > New Profile. You can so this directly in an elevation view to draw it in situ. These profiles can also be bent to a curve (see image).
Ralph Wessel BArch
Active Thread Ltd
