concept design drawing
I am starting a new project and I would like to draw the concept designs like volumes linked to stories height. To be more specific, I would like to draw only the area of the rooms, with no walls and then convert the area automatically to a a volume via linked to the height story. When I have the concept design approved I will start drawing walls and so on.
To summarise it is like if I start designing creating zones instead of walls, stairs and so.
Thank you
1 REPLY 1
felcunha
You can draw zones using manual methods instead of Inner edge.
After that you can show your zones in 3D using Filter and Cu Elements in 3D under View-> Elements in 3D view.
Additionally you can change the surfaces of the zones to better view
Felipe Ribeiro Cunha
AC 26, macOS Monterey
