‎2008-04-29 05:14 AM
‎2008-04-29 02:59 PM
‎2008-04-29 11:06 PM
Jere wrote:This is my recollection as well.
If I'm not mistaken, fill and line consolidation is a standard part of archiCAD under the edit/reshape menu.
‎2008-04-30 12:49 AM
Shae wrote:Line consolidation is a part of the basic install. Try getting your facts straight before you complain.
OK I actually found a use for a new archicad function!!!! Consolidate fills! Well i read about it in the manual, and I read in here that i have to load it, But how in the #@&$@#$& do you do that!!!!!!!!! Archicad Ticks me off to no end, all these goodies and stuff, but you have to download this download that install this and install that, add this to that menu. WHAT A PAIN.
‎2008-04-30 12:50 AM
‎2008-04-30 03:00 PM
‎2008-04-30 03:05 PM
‎2008-05-01 01:18 AM
Thomas wrote:...per the post you refer to -- this is KEY.
Normally, new commands in a new version are available in the new default work environment. It's a good reason to start with that when you migrate, instead of just transferring your old WE.
‎2008-05-01 03:01 AM
‎2008-05-01 03:14 PM
Shae wrote:Then why didn't you just post this to begin with?
perhaps it wasn't clear to everyone. I know where it is (or should be in this case) in the menu, so spotlight wouldn't help. It was not showing up in my menu. Due to some crybabies request that you be able to move menus around, it was no showing up when I upgraded and brought up my work environment up from 10. Frankly it wasn't missed until I was looking at manual one night, and thought, wow I might be able to use this feature, and I looked for the feature and it wasn't there. Karl I am on tiger by the way, and it wasn't in my menu so it wouldn't show up. Anyway, I went into the work environment in order to add it, and I found it in the structure where it should be, BUT I couldn't add it. The add button was greyed out. THAT was my question and frustration. .
