convert a file
please ,i want to convert a file from archicad to autocad.thanks
5 REPLIES 5
NCornia
Graphisoft Alumni
Graphisoft Alumni
If you have ArchiCAD, go to File>Save As and select DWG as your file format.
If you do not have ArchiCAD, download it from www.myarchicad.com or ask the person who made the ArchiCAD file to save it as a DWG.
HTH
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
Erika Epstein
If you want to save a 3D version, open the 3D view and from there save as DWG format.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
thank you very much
thank you very much
HTH
thank you very much
