Tom Krowka
copy a view set?
Any way to copy one view set from one .pln to another?
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
2 Replies 2
You will need to use the Organizer from the Navigator. Click the top left button in the Navigator then Show Organizer. Here click the top left button again and choose Browse. Locate the .pln file you want to copy from and Open it. The external file should now be listed in the Organizer on the left side. Just Choose the View Map button then Copy what you need to the right. Hope this helps.
Not the views themselves.
Views from other projects can only be brought in as external drawings.
James Murray
Archicad 29 • Rill Architects • macOS • OnLand.info
