‎2005-05-01 12:15 AM
‎2005-05-01 01:23 AM
another Moderator
‎2005-05-01 01:27 AM
‎2005-05-01 02:00 AM
another Moderator
‎2005-05-02 06:51 PM
Hassanen wrote:I would advise you to rethink your strategy; you will save time by cleaning the intersections and having clear and correct elevations and 3D, and plan too, than patching up. One always forgets to update ...
Is there a way of covering up some lines that are showing on my elevations and sections?
These lines are from certain walls not intersecting, I don't want them to intersect on the plan to represent different wall types, however on the elevation everthing will be covered with stucco, so there will be no line between them.
‎2005-05-03 01:18 AM
you will save time by cleaning the intersections and having clear and correct elevations and 3D, and plan too, than patching up.what do you think the best way to represent this case properly? if I intersect the walls the fills meet at a 45 degree angle as opposed to the way it should be (similar to the picture)
‎2005-05-06 09:05 AM
Hassanen wrote:Try intersecting the walls differently.you will save time by cleaning the intersections and having clear and correct elevations and 3D, and plan too, than patching up.what do you think the best way to represent this case properly? if I intersect the walls the fills meet at a 45 degree angle as opposed to the way it should be (similar to the picture)
‎2005-05-06 09:01 PM
‎2005-05-07 02:50 AM
Djordje wrote:I agree Djorde but have you never had a line you cant get rid of?
‎2005-05-07 08:31 PM
Ted wrote:this works for the plan, but the line between the two walls still shows on the elevation. I agree that it's always better to build things correctly as opposed to covering things up in 2D, but nevertheless sometimes you just need a fast fix.
You might try using the 'intersection hierarchy' setting availiable in the Layer Combinations diaglog box. You would have to isolate the two walls on separate layers, but you could use different numbers for the setting and 'force' the plan to display a 90 degree junction at the intersection if this is what you are after. You may have to have unique fills filling each wall cavity too.
