crash while changing fontstyle
Though I have installed latest hotfix 1183 AC10 INT crashes when usung ISOCPEUR font style
any clue
thanx in advance
4 REPLIES 4
Djordje
any clue
thanx in advance
What crashes? What are you doing when it crashes? Why are you using an AutoCAD font? What are your computer specs?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
in the title block in layoutbook when i change the font style to ISOCPEUR the computer crashes. i was using this font in AUTOCAD so i thought of continuing with it. this doesn't happen with other fonts
thanx
Djordje
Is there any reason for NOT using these "AutoCAD" fonts? I also use ISOCPEUR, with no crash trouble. The only thing is it sits a little high in its bounding box. See image. (Leading value is 100%)
Is there a similar ISO font which is Archicad friendly?
Cheers
Djordje
No reason why not to use them ... if they are TTFs (Windows) except for their not so good legibility - the original SHX were made for pen plotters and I reembert having pen weight issues even with associated TTFs, so avoid them as and when I can.
Djordje
HP Omen
