creating footings for columns
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2009-09-27
04:31 PM
‎2023-05-25
05:48 PM
Rubia Torres
With the limited knowledge in archicad ,i think it can be done in 2 ways.
1) is to use concrete walls for the footings, and using a slab for the base on the footing.
2)use complex profile in wall tools .
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-09-28 04:11 PM
I know I could have added some "space-clicking" tricks for faster editing if one is to trace over an imported DWG
Cheers
Francois
Worldwide Digital Imaging
Formerly posting as RanXerox
"A little bump will help blur your reflections"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-09-29 11:23 AM
and how to do the same thing for a step footing(fig given in previous post)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-10-28 03:08 AM
I'm just in the process of learning how to create footings - I followed Francois's step by step but how do you get the option "add new points" ?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-10-28 10:04 PM
kiwistudent wrote:Welcome to the forum!
With the mesh selected and the mesh tool active, draw some points on the surface of the mesh. Click twice on the last node (or once on the first node if you have formed a closed polygon) and the 'add new points' box will appear.
Hope that helps!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-10-28 10:50 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-10-28 10:51 PM
Might be better to create one then make an object for the rest. With a model you could modify the script to turn off the 3d function which for the most part is redundant as you cant see the footing through the dirt any way and even if you can see them they can be rather confusing if not setout in a perfect grid.
OSX 10.15.6 [Catalina] : Archicad 22 : 15" MacBook Pro 2019 [/size]
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-11-03 09:24 PM
I have the student version of ArchiCAD 12 - I followed the three tutorials but they don't suggest how to create footings hence me using the mesh option. It seems the easiest way to do it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-11-03 10:44 PM
kiwistudent wrote:
I followed those instructions but I do not get the option "Add new points" - I get the little toolbox with 11 options (i.e add to polygon, fillet, elevate etc). Is it supposed to come up there?
Kiwistudent, With mesh selected and still with the mesh tool selected and the rectangular geometry method selected, you draw inside the mesh and the add new points/create hole will pop up so can select either.
You will 99% of the time use slabs, walls, beams, complex profiles for footings. The main thing for new users to remember is that most tools can be used for other things and not just for their title.
If you are stuck on anything you can ring GSNZ on 09 4893235 and get an answer straight away. The quickest way to learn.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-11-03 11:10 PM
I prefer using the forum as I'm Deaf so can't hear over the phone. Thanks though
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-11-03 11:24 PM
Special Construction>special Structures>Basic Shapes>Polygon Prism.
Would this work?
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
