curtain wall-positioning on plan vs on section
Hello, I followed the tutorial to draw a curtain wall on section, then the positioning on plan does not match right positioning on the wall corner,
Please advice
1 Solution
I really don't know the solution to your problem.
But has it anything to do with the location of the section line in plan?
I quickly looked at the video and I think it said something about centring the curtain wall to the section.
Maybe the section line is not in exactly the correct location in plan?
Or it could be that the tutorial is for an older version than what you are working in?
There may be some subtle difference between the versions.
Fortunately you should be able to just move the wall in plan to the position it should be.
Go to post
3 Replies 3
The problem happens after draw on section then show in the plan:
the center of the mullion is deviating away on the edge of wall, but how to set it match on the center of the Grid?
yes exactly, the section line shall be at the middle of the towe, which I had ignored that
Thanks Barry
